Marine Fire Extinguishers
Rick mentions that the color of the fire extinguisher doesn't matter for marine use - but if I recall correctly, to be USCG legal, the mounting does matter - it must be metal rather than than the free plastic one that is usually packed with most units you buy at Lowes, Home Depot, Walmart, etc.Another tip about fire extinguishers used on boats (or motorhomes, cars, etc) - all of the vibration that vehicles are subjected to can cause the powder in a fire extinguisher to become packed - thereby lessening its effectiveness. Periodically take your extinguishers out of the bracket and turn it upside down a few times, shaking it - causing the powder to move around. That is something that the USCG Aux. will do as part of the courtesy Saftey Survey - it's not enough to just have the extinguisher, it needs to be properly mounted, in an accessable place, and functional.Good Luck!Tim BroganApril IV C350 #68Seattle
