After a week in Catalina, my 420 Passage has developed a fresh water leak. I am going to have to install some new pex hose if I cant find the leak at a joint on one of the manifolds. I have two questions and also am looking for thoughts.
First, I figure that coupling the new pex line to old and then feeding through as necessary would be best option. So what is the best way to couple two lines together for runs?
Second, If the leak is at a coupling or joint, I cant find it. I can hear it when the system is pressurized. It sound like it is aft of the galley. For those familiar with the 420, I have found a manifold under the fridge that appears to send two lines aft and two more forward to the sink. The next manifold is in the aft head above the toilet. It has lines headed to sink and swim bridge. All these are dry. I cant find any other manifolds. Anyone know? Surely Hunter would not have covered up a manifold... argh
I was thinking of getting some t valves for the pex to try to isolate which line is leaking. Its standard half inch pex. Is this a home depot option?
Thanks
Thanks
