don z
the last time my yanmar 2gm20 mixing elbow clogged, i had the yanmar guy change it. this time, i want to do it myself. if i remember correctly, the union between the elbow and the exhaust manifold is the kind of two-directional screw that pushes the parts apart or pulls them together as you turn it with a wrench. when installing a new mixing elbow, do the threads need to be coated with pipe dope or tape? if so, what kind? also, what about the little elbow fitting that connects the raw water hose to the elbow? does it need to be pipe doped, and with what kind. lastly, can these things be cleaned out? if so, what's the best way?thanks!
