Removing P42 mast
Hi John, I last removed the mast on my 1991 P42 9 years ago, and I have no memory of the wind transducer disconnect. However, I was personally involved in it, and I remember that I had no trouble disconnecting all wires at the mast base and getting them through the conduit. My conduit was also filled with silicon from a PO, and it cleared out easily and without any damage to the wires in the conduit
I later replaced my radar, including the antenna on the mast. I didn't drop the mast for that job, and was able to thread the thick antenna cable down the mast from above by doing a rudimentary "splice" job attaching the new cable to the old with some heavy thread and duct tape. I was able to access the top of the conduit, and form a proper "drip-loop" by loosening the shroud diamond and removing the attachment point hardware right at the mast, just where the drip loop is located. That provided me enough access to form the drip loop and visually inspect everything there. It was then easy to replace the mast fitting and tighten the shroud diamond again (to its previously marked spot on the turnbuckle).
I had to cut the radar cable and install a new junction box for it, and while I was at it I installed a new junction box for all the cables coming through the mast conduit. I remember that the VHF antenna connector was a separate cable and connector, due to its size. I just have no recollection of the wind transducer cable connector.
Good luck, and please let us know if the cables are compatible with your older unit. My wind unit is erratic, and probably due for replacement. I also wonder about compatibility, since my gauge at the binnacle appears fine but I expect my masthead unit is going. I suspect the cable connectors may not be compatible, but hope that the wires permit either an adapter or the replacement with a compatible connector after removing the old one. I am replacing my ST7000 autopilot, and I have noticed that on the new (as yet uninstalled unit) there are the same number of wires, but the actual connectors are different. I anticipate some splicing in my future.
