G
Glenn
Caroline has got a busted toe rail. Cutting the wood I think will be a job, but nothing I can't handle. I will however take any advice offered on any of the work. My biggest job I think will be removing 40 sheet traveler bolts, looks like they are very hard to get to. I think maybe possibly I can just drop the nut of the bolt almost to the end of the bolt on all 40 allowing me to raise the traveler enough for toe rail refit. If this is possible the labor of getting the nut started back on to the bolt will not exist. The bolt holes were drilled right between the two top pieces of wood. The rail consist of three one & a quarter x one half inch pieces of teak, one being on the side and the other two on top, laying side by side. The toe rail on the inside is in good shape, the outside one on top, and the side one is busted, thanks to the guy with the anchor the size of a coke can. All advice welcome. Glenn aka Painted Pony
