Replace Thru Hull
Beau: The guy I used to clean my bottom was born under water!! I would not try half the stuff he pulled off. Anyway, rememember this is a 2 man deal with 2 experienced divers. They used this plunger method to replace thru hulls. Some water does get in during the replacement procedure but not much. When the inside guy unscrews the nut and pushes the valve stem out and into the plunger, his hand is over the hole. The water guy then releases the plunger, letting the stem fall away, and shoves in the new stem and pushes the plunger back in place. The inside guy guy slaps on the backing plate, which has the sealent and whatever else they use, and tightens the nut, puts in the valve and they are done. It happens about as fast as I just described it. I would NEVER, NEVER attempt this on my own. Most boat yards have a quick "in and out" where you the boat never comes off the ways. They pull you out of the water, you do your thing and they splash you back in. Some times the cheapest way around things ends up being the most expensive - especially if a mate does not know what he is doing. Once I tried replacing a washer in a shower at home. Unfortunately, I applied too much pressure and broke the connection behind the wall. Not only did I have to get a plumber to fix the mess I created but I had to have tile guy replace a section of the tile. It would have been cheaper to hire an expert in the first place. I never have forgotten my shower experience and I use that experience in a lot of things, mainly in determing if whatever I'm considering doing is something I should attempt. "A man has to know his limitations"
