I like bronze
I know that there is lots of evidence to support the theory that marelon is a perfectly acceptable material from which to make underwater fittings, but I still feel better with bronze down there. In part, this is because here in Maine it is not impossible that at some point the water the boat is in will freeze before I am able to get the boat out. Bronze is a lot more likely to survive ice expansion than Marelon. Evidence to support this is largely anecdotal, but all of the commercial boats that winter in the water here have all bronze fittings.In your particular example, the zerk fitting is as important as the strength. The ability to keep the ball propperly lubed will go a long way toward increasing ease of use if you only flip the thing at long intervals. I would maintain there is a safety factor there as well because if the valve is easy to operate you will not have to put a lot of stress on the through-hull itself to use it. In the course of double checking my boat before launch this past april, I discovered that my outlet seacock was impossible to operate. I used a breaker bar on the handle to final get it open, but in doing so I loosened the through-hull itself. This is, of-course, the night before I planned to launch. (Insert image of Justin frantically changing his through-hull and reinstalling ass'd plumbing as the hauler taps his foot waiting.)Justin - O'day Owners' Web
