V-25 keel cable
On checking the archives, I was surprised to find relatively few informative pieces; one of the most about keels contained the word 'memeorable', so a search will turn it up. Its more about coating metal keels. I have a recent post about removing the keel titled 'Under your bonnet', (don't ask why.) Basically, its not very possible in the water or on the trailer, which means the boat has to be on the hard on stands...proper stands if the keel is going to be moved about. If you are going to do major things to the keel, its probably worth the cost to have a yard put it on stands for you. Consider replacing the winch if crusty, from Havencraft or Grainger or other sources mentioned in the archives. Some people increase the cable size; you can swag it yourself at a West Marine or have it done. Special attention to the pivot bolt and seals. The thing is heavy, don't plan to hold it manually in any way. More specific info on your situation or procedures would help.
