After several months of trying, this project is finally done. I know there are only a few 27-3's out there with in mast furling but I wanted to share how things went. First and foremost, DO NOT follow the instructions from US Spar. According to them replacing this line can be done with the mast up, it can't. The furling unit is held in place by a cast aluminum piece, that aluminum piece is held in place by four metric cap screws. According to US Spar, you remove the four cap screws and the furling unit will lift out of the mast far enough to get to the knot at the end of the line. In reality, when you remove the cap screws there are small backing plates inside the mast that will drop down so there is no way to put everything back together. Also, the furling unit will not lift out far enough anyhow. I have the mast down and retrieved those small back plates, the lower was laying at the base of the mast, the upper was laying on top of the furling drum. It tool 3 hours, a piece of aluminum boat pole, a stick, a piece of aluminum flat stock and Gorilla Tape to get the backing plates back in position so the cap screws would thread back in, everything is now back together.
Replacing the line with the mast down is actually really SIMPLE: 1.Unwind all the old line off the furling drum, the foil will just spin inside the mast. 2. When you get to the end push the old line back through the hole at the bottom of the drum. It will feed itself out the bottom of the drum and out the base of the mast. 3. Cut off the old line at the drum, but leave a foot or so. 4. Attach your new line to the cut off end of the old line, I used a wrap of Gorilla Tape to hold them together. 5. grab the knot on the old line sticking out the bottom of the mast and pull on it while feeding the new line through the hole in the furling drum. 6. When the new line feeds through, remove the tape and tie a knot in the end. 7. Pull the new line back through the hole in the drum until the knot seats itself in the bottom of the drum. 8. using your fingers through the maintenance plate holes in the mast, turn the foil and wind up the new line on the furling drum. DONE! That process took me about 10 minutes after the 3 hours of putting things back together.
