Replacing the I-Beam
53
- - Nassau, Bahamas
I have removed the compression post, and the trim, and am now trying to remove the rusty I-beam from the bilge. Can anyone explain to me how it is attached to the bottom of the bilge and how I can chip it out? thanks
May 12, 2005
53
- - Nassau, Bahamas
Wow Clean Bilge
Wow, what a clean bilge. My mechanics just drained all the oil from my engine in to my bilge when they changed the oil lines! Unfortunately I am in the Bahamas, where we have beautiful oceans and beaches, but are allowed to pump anything in to them. I have my bilge pump off and will add some strong detergent and pump it in to a bucket. Anyway I like the way you fitted a shower sump in, what make is that as the ones I looked at would not fit. Anyway I am planning on having a stainless I-beam welded. I am looking at extending the I-beam up to the floor level and through the piece of plywood so the compression post actually sits on the I-beam and not the plywood.
steve rainey
ibeam
I had a SS 1/4" made and installed it in mine. 1978 Hunter 30. I used WM apoxy to lock it in place. I came up under the flooring. Adj the Ibeam hight so all the pressure was on the Ibeam and not on the plywood flooring.
May 12, 2005
53
- - Nassau, Bahamas
IBeam
How did you get the old one out? My boat is still in the water so I want to be careful with the grinder!!
May 12, 2005
53
- - Nassau, Bahamas
Help!!
I really need to get this I-Beam out. Can anyone help me who has removed it before? If not I will just have to attack it with the grinder!
steve rainey
help
I jsut cut mine out with a grinder, it looks like more of a job than it really is. Steve Rainey
