Replacing the head
JackK
Aug 27, 2013
12
Oday 272LE Red Bank
Hey everyone. I'm planning to replace the head in my 272LE. Any preference on brand. There is currently an older model Groco installed.
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
Why are you replacing it? You can get an upgrade kit for the pump assembly. The bowl and base should be reusable unless they are cracked. I think you can retrofit a Raritan PHII pump assembly as I think the mounting at the base of the pump is the same. Peggy used to recommend the Raritan as the best in the business. The outlet might not be in the same place so it may mean replacing your hose if you need it longer.
Nov 1, 2010
100
Oday 272 Brownstown, MI - Lake Erie Metro Park Marina
Just bought a new Hand Pump Jabsco Compact Head ($170) and Flexible holding tank ($250) for our 272. Removed old equipment and hoses. Cleaned and used 50/50 solution of Bleach and H20. Will buy new hoses when on sale? Will wait till spring to install new Equipment!
One of the many winter projects... Regards, John
