Replacing the connection to Clutch Handle
7
Catalina 320 San Francisco
All,
I am new to this forum. Last week, I bought my first boat ever (a Catalina 320). Over the weekend, the bolt holding the Clutch Handle broke while docking and the bolt got stuck in. I tried using an easy out but the easy out broke in the drilled hole.
I am trying to see if I can find a spare of that part. I am not even sure what it is called. Here is a photo:
There is Edson A 918 written on it, I checked Edson's marine website, they do have a spare Clutch Handle but cannot find any reference to above part.
Any suggestions?
Thanks in advance,
May 21, 2006
321
catalina 25, 30 montauk / manhattan
maybe start by calling/emailing edison. i had some issues with the clutch handle/cable. needed a couple of replacement screws. just emailed and they not only quickly responded but also sent with no charge.
Jun 2, 2013
2
Catalina 34 MKII Victoria
I had the exact same thing occur a day ago. The mounting screw sheared right off and the easy-out broke off flush when I tried to remove it. I have e-mailed Edson and I'm hoping for a Monday morning reply.
In the meantime, I am dealing with the root cause of this problem. My clutch and throttle controls always required a little muscle so I never knew any different. Now I realize the clutch was almost seized where it goes through the plastic sleeve. To make matters worse, the head popped off the adjusting screw so I cannot get the shaft out as you did! I am working in some WD-40.
I may end up at a machine shop to get both screws removed.
Can anyone tell me why the throttle control side has a removable bolt (presumably for lubrication) while the clutch side does not?
Regards,
Paul...
Jun 2, 2013
2
Edson got back to me with the part number which is # 960-A-938 available @ $51.00 which includes a new bushing and bolt. I could not find the part online so I was told to phone in my order. It's now on the way.
Cheers,
Paul...
