Replacing the Anchor Light
Jan 29, 2010
64
Hunter 38 Ocean Gate, NJ
I want to put an LED bulb in the anchor light of my 2006 Hunter 38. My boatyard thinks this anchor light housing can be pushed down and twisted to remove it. Does anyone know if this anchor light housing can be removed this way? I don't want to go up without a screwdriver if one is needed!
Thanks.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Thanks.
take one with you and if you don't need it don't use it ...but if you get there and don't have it and need one :eek:
that will be a lot better than saying geeeeeeee i could of had a V-8 ;)
Dec 19, 2006
5,821
Hunter 36 Punta Gorda
Led
Why not just replace the Anchor bulb with a Led Bulb like I did on my
2007 H-36 and works real good and brighter than the the original bulb.
I did go up the mast to see what bulb I had and than ordered one from
Cruising some thing or other but next time I will get the auto one.
There is a ring that just twist off and the top lens lifts off.
Nick
Jan 29, 2010
64
I do know what LED bulb to use, I'm just not sure about how to get the housing off so I can replace the bulb. I am not totally comfortable working at the top of a 60 foot mast so I need to know in advance what I have to do to get at the bulb once I get up there. Nice view, but I only want to go up once.
Jun 6, 2006
6,990
Most twist off. As a general rule you will never get to the mast head with the tools you need. I ALWAYS go aloft with my tool bag AND drag a line from the bosin's chair. When I need another tool I just have the first mate put it in the bucket and haul it up with the line.
Dec 25, 2000
5,918
Anchor Light
Our boat anchor light took the LED bulb that is shown in the link below. The lens cover twisted off, the old bulb came right out and the new one right in. Worked great. The bulb is the standard off set indexed type bayonet.
As was mentioned before, I always take a line up with me that is tied to a canvas bucket in the event I need a tool of some sort to finish the job. All my LED bulbs came from marine beam. Always work, always fit.
http://store.marinebeam.com/double-contact-indexed-bay15d-18-led-surface-mount-cluster/
Jan 29, 2010
64
Hey all. Thanks for all the good advice. I wiill going up the mast as soon as that bulb arrives. Thanks again and safe sailing!
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
Strap Wrench
Took me three trips up the first time I did this. One to find out I needed a strap wrench to get the glass cover to twist off, once to remove the bulb to find out what it was, and the third time to actually make change the bulb.
YVRguy
Jan 10, 2013
479
Hunter 34 Vancouver, BC
I just bought an entirely new fixture with an LED bulb in it. From what I've learned it can be more trouble trying to replace the bulb than just doing the whole thing. But if you've got plenty of time and don't mind going up and down multiple times...
Dec 19, 2006
5,821
NO Need
On 2006 boat should not have any trouble removing the lens and bulb
and I did use that special electrical grease all over the 2 bulb"s and as much of the fixture to keep from getting corrosive.
Nick
Jun 15, 2012
715
BAVARIA C57 Greenport, NY
Just installed Hella LED Anchor light purchased from Defender. It is a sealed unit so no worries about corrosion. Easy to retrofit. Used 1 original screw from old fixture, drilled 2 new holes and used self tapping screws.
