We really like shorter, stainless rails
You can barely see the shorter stainless grabrails installed between the rope clutch and organizer at the link below. It was installed by a prior owner.It is through bolted to fender washers inside the cabin liner. Of course, all the holes through the deck were drilled to one inch, filled with epoxy, and then drilled to 1/4 inch for the bolts that mount the rails.The rail provides plenty of grabbing target at the aft end of the cabin. Forward of that, the shrouds are our favorite hand hold, and they are a firm support. Another advantrage is that sitting on the (now) smooth cabin top inside the shrouds is now a favorite crew position while underway, or anchored.It does remove a distinctive look of the h27, but we don't miss it.DavidLady Lillie
