Teak Deck on a Mistress
Hello,This is the biggest challenge to a Mistress owner. A new teak deck is an 'easy' way out but you also lose the characteristic appearance of the deck. I don't know of any pre-cut pieces for this boat. I have decided to try and maintain the appearance of our deck for new, with a whole newly laid teak deck as the 'last resort'. This means finding a way of fastening the teak strips on the fiberglass. I don't want screws or holes, because the deck doesn't leak now!Rutger Genberg gave me some advice about the teak on ours. He suggested glueing new strips over the old ones with polyurethane glue. This is what he did on his. I tried this in the cockpit with mixed results -- if the contact was good there is no problem but some of them have started to loosen. I will probably try again with some sealant around the edges.I can send you Rutger's comments. They're in Swedish but you shouldn't have any problems.You have seen 'Vackra Båtar Seglar Väl' by Ingrid Kajser? A book about Enderlein, and several sections about the Mistress.Jonathan
