Replacing shower drain hose?
Apr 19, 2020
74
Catalina 310 Kenosha, WI
On a 310, anyone know how to access the bottom of the shower drain to replace the drain hose? It's really tight in there. Also, if anyone know, please confirm that's a 3/4" OD / 1/2" ID hose?
thanks!
SJN
May 30, 2021
37
Catalina C310 Seattle
Hello! My shower drain would not drain. As you say accessing the hose under the shower pan is very difficult. I ended up using an air compressor and was able to blast the existing hose mostly clean using air. Had that not worked, my plan was to disconnect the hose under the shower pan, most likely requiring cutting an access hole in the pan (or, if lucky I might have been able to reach the undershower end of the hose by taking out the house battereis that reside under the settee, however there there is a rib under there on my boat that would most likley be in the way.) Then disconnect the other end of the hose where accessible in the bilge and attach a new hose to old hose and pull it through. Then repair the shower pan. Perhaps someone has come up with a better solution. I hope so!
Mar 6, 2008
333
Catalina 310 Scott Creek, VA
I wondered about that also, and though I would try to disconnect the sump fitting and see if there is enough slack to lift it up and get to the hose clamp from the head area? Have not had bad enough clog to attempt, but had issues with the hose that drains the fridge
Oct 3, 2011
835
What is going through your shower sump...WOW!, I would try chemicals first, than maybe go to The Head Mistress to see what she recommendeds for chemicals- KO, CP, Etc?
