Replacing shift & throttle cables on 2003 Hunter 386
Jun 2, 2004
12
Hunter 40 Lake Texoma
Hi SailboatOwners, hope your day is going well. Anyone experienced replacing the shift & throttle cables on 2003 Hunter 386 have any suggestions? Its a single shift lever arrangement. Thank you in advance for your help... Regards Jim
Sep 26, 2008
765
Hunter 340 0 Wickford, RI
If you can show a few photos of what you have and can see at the moment. That will help a lot. The cable itself will be tied into a bundle of other cables, wire and more that you don’t see under the floor boards.
It‘s a job that has been done and able to be done by others here. You just need to follow the cable and measure as you go along and allow for the gradual bends you find.
I did mine on my 340. The cable bundle ties were the type that were screwed into the side of the stringers and I was able to unscrew them and allow slack so the new cable could be fed through.
I wasn’t lucky enough to be able to tie the new cable to the old and pull it through. But all in all it wasn’t the hardest of jobs. Contact the store here on this site, they may have the proper length requirements you need.
I have photos in my media here that you can take a look at also.
7,673
Alden 50 Sarasota, Florida
Having done this on few different boats over the years, I’ve found:
Not all boat of the same model have the same exact cable length. Its best to pull the old cable and measure to ensure the proper length.
The number and location of cable support clamps varies with the guy who installed them and not by model.
Its sometimes easier to rearrange the new cable and clamps rather than follow the as-built configuration as trying to route a new cable in a boat with the deck on is different then when the boat was being built.
  • Helpful
3,946
Corsair F-24 MK I Deale, MD
If you know the length, you can often pull the new cable using the old cable and a coupling nut.
