Bob Alden
Sailors,While sailing today I had a cable fail on the shift linkage to my Yanmar YSM12. I have a 1979 h30 with the Edson pedistal and wheel steering. The cable end is easy to get to at the transmission side on the Yanmar, simply requiring the removal of a pin to disconnect. The end that failed is the threaded portion at the yoke that ties into the forward, neutral, reverse shift lever. I have been unable to extract the cable from the pedestal. I can't seem to pull the cable through from below or topside. It seems to be locked, fastened or captured in the Edson wheel steering pedistal base.Anyone have experience with replacing this cable or one similar to it with Edson wheel steering? Specifically, how do I remove the failed cable?Thanks much....Bob Aldenh30 "Summer's Glory)
