My Yanmar seawater pump started leaking, I removed it to disassemble to replace seal. however I cannot remove second nut on shaft, the one inboard of pulley, it has a curved arrow on it pointing CCW as viewed from pulley side.
I suspect it is Left Hand Thread since it doesn't want to loosen in the normal way, the pump is made by Johnson AB (Sweden) and is a F4B-903.
Does anyone have any direct knowledge of this pump, and the disassembly procedure, the Yanmar service manual has no specific instructions.
