After spending hours of research to eliminate the obnoxious odor that my boat has, I feel the best place to start is by replacing all the marine sanitation hoses. The pump out hose is in two sections. One goes from the deck pump out fitting down to a plastic "Y" that was originally used for over board discharge. The discharge side has been capped off and no longer used. The other portion runs to the holding tank. The hose coming from the deck has cracks all over it so its pretty obvious it should be replaced. I am guessing the part that runs from the "Y" under the floor to the tank is original.
My goal is to eliminate to "Y" and go strait from fitting to tank. Since the boat is 4 hours away, I was hoping somebody who has done this would tell me how much hose I need. I will also be replacing the hose from head to tank. I will be using Trident 101 and don't want to buy any more than I need. Also any other tips or advice on replacing the hose that runs under the floor would be greatly appreciated. Thanks.
Adam
Adam
