Brian Peyton
Hunter 340 - 2000. Yanmar 3GM30. Replacing raw water intake hose. Original hose is 5/8" wet exhaust type. Hose barb on strainer is 3/4". Barb at pump is 5/8"(could be a metric size). Good engineering huh!Should I use 3/4" hose and just clamp down tight at the pump end or replace the strainer hose barb with a 5/8" and use 5/8" hose? I am concerned I may break the little plastic strainer body attempting to remove the old hose barb fitting. Besides wouldn't the 3/4" hose provide a little better flow? I will use the high quality wet exhaust type. West Marine is $5.49 a foot.
