W
Walt
Have a couple of marelon ball-valves to replace on my 94 Catalina 36. Looking for advice on removing and installing new ones. It appears that if I hold the nut securely which is locking the thru-hull part component, then the ball valve assembly should just spin off. I should then be able to spin a new one right on. Have never done this before. Fortunately,the boat is out of the water.Also, is it ok to replace the marelon unit with a bronze ball valve onto the marelon/plastic thru-hull.Thanks, Walt
