Position of bilge pump switch
I don't think you want to put the switch lower than the pump intake. If so, you could end up in a situation where the switch turns the pump on but the pump runs dry until it burns up or drains the battery, whichever happens first. If the switch is immersed but the pump can't clear the water the switch is in the switch will call for the pump to run continuously. I think the switch should be at the same level as the pump, and if there isn't room for both, the switch will have to go to the next higher location.I saw an LED cabin light at West Marine - it looks just like the traditional ones - but it was $41, so I'm going to wait for my old one to crap out.
