Replacing Hunter 410 Aft head hoses
16
Hunter 34 Punta Gorda
Has anyone had to replace the main discharge hose from the head to the holding tank. The plunger on the Head builds up pressure when pumped. I have checked the all vent hose blockages, replaced the Joker valve, put a "snake" into the head end, but it only goes about 3 ft and then is blocked, but does not have any material on it when extracted. I assume there is an anti siphon loop somewhere
Thanks in advance
snows
Aug 22, 2011
30
Hunter 410 Charleston, SC
No loop. Mine goes straight from the head to the holding tank. You can see the hose if you lift the floorboard covering the house battery or the one just aft of it.
Apr 23, 2012
69
Hunter 430 Kemah
If I am not incorrect, the same on the 430, same concern ,no loop but the hose makes a bend about 3.5 ft down and in time the hose has collapse causing a kink,tried to install a hose clamp to straighten it out but no good. Had to replace hose. When you do and look down it you will wonder how anything got by.Good luck.
