Replacing hot water heater
Oct 28, 2023
16
Hunter 29.5 Midland, On
Anyone have tips/instructions on how best to disconnect the heat exchanger hoses? I have a Hunter 29.5 and a closed engine heating system.
Jun 17, 2022
236
Hunter 380 Comox BC
You can use a dinghy air pump to get the most of the coolant out of the hoses.... good time to do a hose replacement as well if they are more than 15 years old ?
When I replaced the water heater on my boat (about 7 years ago), I lifted the coolant hoses above the engine, and gravity kept the coolant in place. After installing the WH in the boat, I attached the hoses to the new tank and added some antifreeze to top the unit up.
I'm not sure about your unit, but once I released the upper of the two hoses, the liquid flowed out of the other hose towards the engine to find equilibrium. It was one of the easier projects on my boat.
Likes: Timm R Oday25
Oct 28, 2023
16
This sounds like a great idea. I was wondering about using gravity to my advantage. Thanks!
Oct 26, 2008
6,277
Catalina 320 Barnegat, NJ
If you haven't changed your coolant in a few years, you may as well drain and replace all the coolant. Probably a good time to change out the hoses, too. If you are going to replace the water heater, may as well refresh the entire system.
Jun 2, 2004
3,554
Likes: lacoursmarc
Hunter 30_88-94 Ipswich, Ma MA
I put a U fitting with two hose clamps on the hoses a let the coolant circulate back to the engine. Like jssailem said, hold the hoses up while you’re installing the fitting so the coolant doesn’t run out.
