Replacing hoses
252
hunter 260 Ruedi Res.
I have a 98 Hunter 260 an am going to replace all waste hoses this off season. What brand or type do you recommed? Regarding the 1 1/2" looking through the catalogs I see basically two types, a black rubber "premium" hose and a white flexible plastic type. They are about the same price, but which one blocks the odor better/longer? On the vent hoses and water inlet I have only found the white corrugated hose. Also should I replace the siphon break on the water inlet hose while I'm there?
Dec 2, 1997
9,010
- - LIttle Rock
Best hose is AVS96
It's been proven in independent testing to be 16x more resistant to odor permeation than any other hose. $5/ft, cut to any length, direct from the mfr: http://www.aussieglobe.com/avs96.htm However, it's only available in 1.5". Use Shields or Trident #148 white sanitation hose for head intake and vent hoses. As for your vented loop...you shouldn't have to replace it...just clean it and replace the air valve if necessary. I suggest you check out the link below before starting this project.
