Replacing H34's Depth Transducer
PGIJon
Mar 3, 2012
856
Hunter 34 Punta Gorda
Well it seems as though I'm going to put the boat on the hard in order to repaint the bottom and while I'm at it, I wanted to replace the speed log transducer that is in the thru hull in he forward cabin. I believe that the old transducer is about 1 1/2 inches in diameter. I want to replace it with the Raymarine P319 transducer which is compatible with my e7d. However this transducer is 2" in diameter. Can I simply enlarge the existing thru hull? Has anyone replace the older transducers with newer larger ones up front? Thanks... Jon
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
I think you have a speed wheel and a depth transducer? I am not familiar with the P319, but I wonder what the equipment configuration is.
PGIJon
Mar 3, 2012
856
Your right splax.. I have both, however according to the PO the speed wheel died several years before I purchased the boat. The depth transducer still works, so I thought I would leave that in as a backup up and use the speed wheel's thru-hull. -Jon
garyg
Oct 14, 2005
22
Morgan 33 annapolis, md
thru hull data source
I am considering doing the same thing, I have a thru hull fitting from my old Kenyon speed
transducer. A site recommended by Garmin because it gives you all transducer options and dimensions is airmartechnology.com
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Dst800p-a
What not put in a DST800P-A yes more $$$$$ but it does speed,temp,depth
for ST60.
I just did it and you can even remove it when in water for cleaning,:eek::eek:
yes it can be removed and a plug goes in it place but :eek::eek::eek:water does come rushing in and need to be fast and will try using a rag or towel to cover while making the change over.
My older speed transducer had a flapper to help keep so much water from rushing in but this one does not.
I think it the DST800P-A was $205.00.
Nick
