Replacing h26 ports
Aug 4, 2016
19
Hunter 26 Kingston
I bought new ports (the ones that open) from the website and there is no screw holes on the outside frame. Am I supposed to drill my own or just seal it with port sealant and apply preasure with a sandbag?
I looked for a thread on the topic already but didnt find on
Crazy Dave any help here?
Nov 6, 2006
10,162
Use Dow 795 for sealant/adhesive.. Port is attached from the inside.. Good to chamfer the outside edge of the hole so that you can get a lot of sealant around the spigot of the port.. then, after masking the cabin sides, stick the trim ring on.. it can be clamped if necessary using clamps and blocks attached with the port open and the lens off if necessary.. This post from Stu's group shows one way of clamping..
http://c34.org/bbs/index.php/topic,3241.0.html
May 6, 2004
196
- - Potomac
Are you in Kingston, Ontario? Don't bed with Dow until night time temperature rises to 60 degrees F and stays there. If you re-bed when it's still cold outside, you will be re-bedding again very soon. Good luck with the job.
Aug 4, 2016
19
Hunter 26 Kingston
Kloudie.... wow..... I feel dumb. That clamp is the simplest and most genius thing I have ever seen. This will definitely be my install technique.
and wait for some nicer weather like Drew said
Thanks for the help,
