Spinlock PXR
Syversens, the traveler line is locked by a Spinlock PXR cleat on each side. They can be locked (pull down)or unlocked (pull up) with one hand. You can see in the photo that I mounted them up on a little teak block so that it is easier to pull down on the line to lock them. They work great!My original dodger had 12" zippers on each side and you ended up reaching through the zipper to load or unload the cams on the Lewmar traveler...a real pain. Also, the zipper patches obstructed my forward view significantly.Yes, the Spinlocks can be unthreaded and rethreaded in a nano second if you want to remove the dodger.Since my boat has mid boom sheeting, I have found that I must use the traveler when sailing to weather. If I just lock the traveler in the center I give up 10 degrees or more of pointing ability.Agaliha
