replacing flexible shaft coupler
W
William Hankins
I need to replace the flexible shaft coupler on my ODay 27. It is equipped with a Ferryman diesel and was original equipment on the boat. Can someone advise help me fine a source. Thanks.
K
Kevin
Coupling
Hello William, Do you know what flexible coupling that you have? If not please describe it to me and possibly I can figure it out for you. If you provide the transmission make/model, the reduction gear in it and your make/model of the engine we can also figure the correct size of R&D unit for you. kwoody@pyiinc.com Hope this helps you. Kevin
