replacing cushion foam
aeb
May 18, 2004
12
- - Seattle
I need to replace some of the foam cushions on the interior dinette couch. Can I use any high density foam or is there special "marine foam" I should use. Thank you!
Jun 2, 2004
5,802
Two sources.
Sailrite does have a cushion foam that is "marine-like". You can read about it on their website. Select 'Online Shopping' and then 'Foam' on the left hand side. My sewing bible, 'The Big Book of Boat Canvas' likes a closed-cell foam called Airex. If you make stuff for your boat it is a good book for your library. Author is Karen Lipe. Be prepared to shop, foam is expensive.
Dec 10, 2003
7
- - Everywhere
Try this
This worked real well for me and was cost effective. For longer or wider pieces use their spray adhesive which makes a very strong joint. Use electric knife to cut. LInk below
Jun 3, 2004
38
Hunter 376 Wickford, RI
Foamorder.com
My wife make window treatments and does alot of residential window seat cushions. She gets all her foam from foamorder.com They have a wide selection of foam types and will custom cut to your size. They also wrap the foam for a real professional finish. They also do matteress foam Russell
A
Allen
foamorder.com
Hey Guys, I have to second the recommendation for foamorder.com. I needed a last minute piece of foam custom cut & shipped last minute to accomodate an 11th hour crew member who decided he wanted to stay on the boat during a race weekend. They were prompt & courteous and they did a great job. I highly recommend them. They also have many different grades of foam for various uses so you should be able to get the right grade at a competitive price. Good luck, Allen Schweitzer s/v Falstaff C-30 Hull #632
Dec 3, 2003
2,101
Upholsterer
I bought a berth mattress of high density foam from an upholsterer. I took the old one in to use as a template.
