Howdy howdy to all. 'New member here. I have a '79 Hunter 37' Cherubini Cutter & sail out of Providence, RI.
It is necessary to fully replace at least one of the chain plate bulkheads/knees. These have a heavy-glass exterior with a plywood core (or a ply bulkhead with heavy heavy glass/web coating). I discovered at least one of these cores rotted, and it's time for a complete rebuild. I've done a fair amount of glass work - above and below the waterline, but admittedly this will be the most challenging glass project for me to date.
BTW...there are at least a few whispers online that this core may be able to be replaced w/o cutting it out - but I'm dubious that this would be the A-1 job that I plan to do. Disagreements and suggestions to this are welcome!
At any rate, I thought that this would be 1. a great place to get steerage advice and 2. to create a record for anyone who may follow. I have seen pics of ply bulkhead replacements, but I can't seem to find post(s) of exactly what I am contemplating. So, here goes...be gentle.
My preliminary plan is to
1. Loosen and remove the shroud to which the chainplate in play is attached and secure it to my robust toe-rail.
2. Secure main halyard to further ensure rig integrity during project.
3. Remove any/all joinery surrounding the bulkhead/knee to be replaced.
4. Remove chain plate and backing plate from bulkhead
5. Tape off deck to prevent leaks during repair
Then the real work...
6. Cut the entire bulkhead out to the hull. (?Maybe leave a bit of the glass attached to hull, creating a "slot" for new ply?)
7. Grind/sand as necessary to expose the hull's bare glass
8. Out of marine-grade ply, cut the required replacement bulkhead.
9. Glass the edges of the plywood cutout.
10. Heavily glass & web & glass, etc the plywood in place.
11. Mark & drill bolt holes in bulkhead
12. Install chain plate
13. Rebed deck "beauty plate" over chain plate fitting using a Polysulfide sealant.
14. Add a step to post so that my post does not have an unlucky number of steps.
This is a plan in progress, but I respect others' advice who have been there before. I am grateful for any additions/suggestions/etc.
Cheers,
Mike
Cheers,
Mike
