Flammable Refrigerants
There are many new refrigerants out there and even some with flammable properties. Those with Propane/Butane may be expectable subject to narrowed use limits. Example there is a product R414 called hot shot that has a very small amount of butane in it. The EPA has listed Hot Shot on their acceptable SNAP list for automobile A/C systems. The EPA dues not approve refrigerants they evaluate them for effects on health, safety and air quality. Refrigerants used in boats unlike cars do not have high air flow through the bilge area and these flammables are heavier than air they could collect in the boat’s bilge. Because the EPA’s SNAP list dues not have a category for boat refrigeration to except or reject refrigerants, I have recommended that any amount of a flammable chemical in refrigerants was not acceptable.Without knowing the refrigerant name and number there is no way to tell if it is compatible with the oil in your compressor. If you have an old system and the original refrigerant was R12 then the oil would have been mineral. If the refrigerant added to the system was Hot Shot then it is listed as compatible. If it was Hot Shot, put in the system I would not be overly concerned, as there is less than ½ pound of it in your system and in that ½ pound there is only 1.5% of it butane. If the refrigerant is lost again and it probably will. I would repair the leak and put R12 refrigerant back in the system. What would concern me is if you can't determine what is in the system, straight Propane could be there, and you might not notice the differance.I do have a page in my web site on refrigerants. http://www.kollmann-marine.com
