Has anybody replaced the sheaves on the cabintop turning blocks that run the halyards from the mast back to the cockpit? I purchased the replacement sheaves from CD last fall. I expected them to be through-bolted with the nuts and bolts exposed inside the cabin near the curtain shown in the photo below. However, nothing inside. The blocks are inline with the mast on the cabintop and a little outboard of the mast supports. Looking at the two mast supports inside the boat, I assume there is some sort of beam structure spanning the two mast supports.
So, my question is, are these blocks threaded into a mast support beam sandwiched between the cabintop and interior liner? Or, is there a small gap between the cabintop and liner that I need to cut into to access the bolts? Thanks!!!
