A
Anthony Bavuso
The previous owner of my 25.5 unfortunately did not regularly caulk the chain plates and therefore there is extensive water damage to the port side bulkhead and the bow most areas of the cabin floor. Additionally due to the wood rot the port side chain plate moved around a lot and wore away the nearby fiberglass all the way down to the wood support that is laminated inside. This wood is also rotten. I plan to fix this when the bulkhead is removed. I am going to remove all the rotten wood and replace it with epoxy.As a winter project I have chosen to replace/repair rotten wood in the ceiling, the port side bulkhead, and maybe replace the floor while I'm at it. I figure that while I am replacing the bulkhead pretty much all the stuff I need to remove to replace the floor is already removed so why not? I have already gone a long way toward removing the port side bulkhead.I have a few questions which are as follows. What wood should I use to replace the bulkhead? Also where does one buy a replacement cabin sole? I am going to call Hunter Marine and see what they have to say shortly.Bob Getchell, if you're out there, I noticed in a previous post that you had also done this. Any help you can offer would be greatly appreciated. Do you have any pictures?Thanks.
