teak and holly replacement
Probably all of the Cherubini boats had similar detailing on the sole for when I replaced half on my 79 H33 I found the same situation that Tammy did, bungs that had nothing underneath and with the sole fastened to the pan with adhesive. Scratching my head on this one, I decided that the rationale for the bungs is as follows: With a pattern of adhesive between the bottom of the plywood and the pan there would be potential for water once introduced to be held there to the detriment of the teak and holly so Hunter attempted to provide an outlet for any trapped water by drilling these holes which go not only through the teak and holly but also through the pan and then enlarged the hole in the teak and holly for a bung. Now there is a drainage hole down to the hull itself and thence to the bilge for any water trapped. When I replaced my sole I made sure that the original holes in the pan were kept open but saw no need to install new bungs. Good way to cut for a new sole is to get the old one out and use it for a pattern. Once cut a great opportunity to head off future water trouble is to epoxy seal the edges and back of the plywood before installing. Even though the plywood is warped to fit the pan contour, it is gentle enough that strategically placed weights will hold it in contact till the adhesive sets.
