Replacing bulbs in cabin lights
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
How do you take this light apart to replace the bulb? Need to replace bulb in the light on the arch.
May 7, 2012
1,522
Hunter e33 Maple Bay, BC
Try popping the outer ring off the flange it is attached to?
Correct. If you look on the outside of the ring there will be 3 dimples, one at 12 o'clock, one at 4 o’clock and one at 8 o’clock. Careful pry the ring off at these points with something like a dinner knife.
May 10, 2004
254
Thanks, it's what I thought but didn't want to break anything. As it turns out, the light in question was on the arch. Found a bird nest up there and it pretty much was a mess. Will need to replace the fixture anyway.
