Replacing binnacle mounted instruments
josh
I am In need of all new instruments on my catalina 30 1980. The Old units are still Semi operational but all wiring is extremely suspect. They are datamarine speed, depth and wind. Oh yeah they are also metric only units. Go figure. I am considering a kit from raymarine which would mount in a binnacle box for edson systems. I would appreciate any thoughts or shared experiences concerning instrument/transducer Replacements. Specifically in regards to the mounting of mast instruments such as Wind speed/direction transducer. Also I am in need of an affordable binnacle mount compass. The ritchie unit on the boat literally disenegrated before my very eyes. Thank you for your input.
K
Ken Fischer
Running a mast wire
In case you missed it, here's a repost on running the mast wire: Several years ago, I installed a wind instrument on an '88 Mk 2 model with the U-Dinette. Your mileage may vary, but here's how it went. Removed the sheeves from the base of the mast. If you don't have these, you'll probably have to drill and access hole 2" in diameter...lots of people have done this. Drop a messenger line down the inside of the mast and pull it out the side. Next, penetrate the sealant at the top of the cabin roof, where the other wires go through, with a fish tape (there may be a stand pipe, depending on the year of the boat). The fish tape will run down to the bottom of the compression post. I drilled a 1" hole on the aft face of the compression post, a few inches up from the bottom. This hole is covered by the U-dinette. If you have an L-Dinette, you will need to replug and refinish the hole later. Using a wire hook and/or long thin needle nose pliers, guide the fish tape end into the hole used by the VHF and mast lighting wires. This is the tricky part. Once you get it, the fish tape should exit with the wires into the bilge. Run a messenger line back to the deck, tie it to the one coming down the mast. You can now pull the wind instrument cable from the top of the mast, down to the bilge. To get from the bilge to the electrical panel, we disconnected a wire from the bilge pump, attached a messenger line, and pulled it back to the panel. Then attached a second line and pulled the wire back to the bilge and hooked it back up. Now you can pull all the wire to the electrical panel.
Jun 3, 2004
28
Catalina 36 Bristol, RI
Try Tackticks
Josh, You could try Tacktick instruments. They do not require wiring or electricity. The only wiring that I know of is to run the speedo and depth to the transmitter unit(?). All the displays and wind transmitter are wireless and have solar batteries. I beleive they are only slightly more expensive than regular ST60s. Sail and Cruising World have done write-ups on them. Les Murray
