Steve Horswill
I have a 78 Hunter 27 with a slight depression around the mast step. It is time to replace the balsa core. I intend to peel off the deck, scrape out the balsa and replace it with something that is not subject to rot. My greatest concren is when the deck piece that is cut out goes back down, I want to get a all the air gaps out and make sure the bond with the replaced core and at the cut seam is at least as strong as it was prior to the deck removal. Any advice would be greatly appreciated. Steve Horswill
