I need to snake a wire up the mast since my anchor light wires slipped into the mast and haven't come out since. I am hoping to snake a replacement wire up the mast through the comp post but am not totally sure if this is doable. I have exposed the wires currently in the comp post(removed one side of the post). Ideally, I would like to jack up the beam just enough to take pressure off the comp post so I can slide it out of the way in order to access the hole the wires are run through. The boat is on the hard.
Here are my questions:
1) do the wires have a connector tucked in the mast or are the wires one complete run? i would like to retrieve the loose wires if possible.
2) i have read several good post here regarding removing the compression post but they didn't mention if the the mast was un-stepped or the standing rigging loosened. Can I jack up the beam without touching the mast or rigging?
3) is jacking the post doable without causing damage else where?
Thanks for any info or tips!
