I am getting foul odors from under the sink in the head. I have sprayed bleach on the hoses which solves the problem for the day but the next time I am to the boat the odors are back. It appears that after 25 years, I need to replace all the sanitation hoses.
I must say it is a "rats nest" of hoses under the sink since I have a "Y" valve to direct to either the holding tank or overboard, an overboard pump along with the hoses for the trap as well as the deck pump out.
Once I remove the sink I can get to most hoses but it looks like the real problem hose to replace is the deck pump-out hose which goes to a "T". That hose seems to take a 90 degree bend just above the right top side of the tank. The right topside of the tank is hidden under the toiletry compartment and doesn't appear to be accessible unless I destroy the toiletry compartment.
Has anyone replaced their hoses and can you give me advice as to the best way to get this "shitty" job done.
