I just adopted a Hunter 27, early 80's. It's a project boat but clean fresh water history. All the bulkheads had been removed for refinishing. During the process, someone made off with them. I bought the boat sans interior woodwork! But it was a great deal for a great project boat... isn't it always?
I need someone with a Hunter 27, like mine, to give me the dimensions of three things:
1. The compression post.
3. The vee-berth bulkhead height at openings, port and starboard, of the climb-through. In other words, where the opening is to crawl into the vee berth, what's the height of the port and starboard bulkhead edge?
If you can measure the thickness of the bulkheads, that would be appreciated, too. The main bulkhead "shadow" appears to be 3/4" to 1" thick. The vee berth doesn't indicate any thickness, so any help you can provide would be great! BTW I plan to laminate up to 2" on the new bulkheads I'm putting together.
Thanks, that should do it. The liner shows very little evidence of the bulkheads, only small screw holes every several inches. Are these boats really that weakly braced?
I'm thinking of glassing the new bulkheads in and through-bolting them, also. Anybody done that before can give advice, would be appreciated. Also, any other info / advice on stiffening the hulls for more stamina?
Thanks,
Jim B
S/V The Next Adventure!
Thanks,
Jim B
