A
Allen
I have to replace the gear changing control cable in my Edson Pedestal. Edson International gives instructions but there is no way once I release the cable holder and bring both throttle and gear cables to the same side that the cable holder can be pulled up past the steering wheel shaft. The cable holder is to large to pass by the shaft so I can release the damaged cable. I have one of 2 options:Try and remove the steering shaft or disassemble the whole pedestal and pully/chain system and pull the cable out through the bottom. I really do not want to take the pedestal apart. Has anyone ever removed the shaft? How do you do that?Allen
