I have spent a lot of time this winter trying to track down a deep-cycle, maintenance-free 4D battery to replace the original on my 309 (#22). I am trying to avoid paying $600 for an AGM, and also having to buy a Group 27 AGM for another $250 because you aren't supposed to mix types, and have had no luck at all. I replaced the 27 a couple of years ago with a Delco Voyager sealed lead-acid with a built-in hydrometer, which is a battery that I and other sailor friends have used on other boats with a lot of success. They don't make a 4D in the Voyager line. Since I am only off shore power when I am day-sailing or going on 8-10 hr. trips up the lake, and I have yet to anchor out in 5+ yrs with the boat, (no good anchorages in southern Lake MI) I am not sure why I need the 4D, but Catalina says I do. I have had several suggestions to just get 2 more 27s and connect them in parallel to replace the 4D. There is just enough room in the battery "compartment", and it would only cost about $200 total. (The Voyager 27 has an AH rating of 95 hrs.) Does anyone know of a reason that this wouldn't work or that I shouldn't do it?
