Replacement windows
1
Hunter 34 vancouver
I'm just in the process of purchasing a 1984 Hunter 31. I notice the plexiglass windows are "hazed". I want to investigate to see how these might be replaced. Has anyone done this and if so what manufacturer did you use, does Hunter still sell these parts, did you encounter any difficulties in replacement that I could avoid? In fact is wise to go through the process for the aesthetic results?
Pearson 365 Ketch Memphis, TN
They have replacement Portlights on this website
AJC-2008 I believe ports on the 1984 Hunters were made by Gray, which can be replaced with Bomar/Pompanette. You can get them directly from the manufacturer OR you can get them faster for less money by using the Chandlery on this website.
