Off with the old and on with the New
I have a couple comments - OUT WITH THE OLD The old stickers come off very easily with a heat gun. A hair dryer might work, but it would have to be a hot one. I used my wife's heat gun that she uses for crafting - worked fine.Be aware, though, that the hull YELLOWS over time. When I removed my swoosh, I the gelcoat was much whiter underneath. I spoke to Greg at Hunter, and he told me that the gelcoat will natrually do this because of UV rays. There are a few choices: (1) live with it - its only noticable if you're up close; (2) wait. over time, it will yellow as well, though probably never as much as the area around it (3) lightly sand the area. Greg suggested the yellowing is only in the outer part of the gelcoat, and light sanding will bring out the white underneath. There are lots of risks with sanding though. Lets just say I did not choose this option.ON WITH THE NEWI had someone put on my new name, but I've since learned a few things. You can get these signs made up at a local shop, and even on the internet - you can do your own designs, choose your own colors, etc. Do a search, or write me an e-mail and I'll share the site name I used (for a different project). Along with the purchase of the letters, I bought some "application fluid". Its really just dish soap thinned out with water, but I left the mixing to the pros, and just bought the product. Anyway, you spray this stuff on before you apply the sticker. It allows you a lot more room for error - you can slide the sticker around a little, or work out any bubbles. When I got it where I wanted it, I left the outer paper attached and taped it all in place for a few hours. When the application stuff dries, you can peel-off the top layer to reveal your new name!Good luck!
