Hi Guys,
Just about to start installation of a Beta Marine 14 into my Vega. I think I have most of the technical aspects of the install figured but, because the original bearing housing was sawn off flush where it exited the boat, I need to reconstruct a new bearing carrier. Having put some thought into this, I'm leaning towards building a bearing housing out of epoxy / cloth in situ to take a standard 1" x 1 1/4" x 4" non-metallic Johnson Duramax bearing (I'm using imperial drive shaft components). I intend to coat the bearing in release wax before bedding into the carrier with epoxy in order to make future replacement easier, as I have read that this is an acceptable method. Now, before I commit, does anyone see any reason why this would not work with the Vega, particularly in regards to water flow into the shaft log? Oh, and the other issue I need to solve is how to align the new housing. Would it be best to do it after engine installation, or before? My guess is after, as I can use the end of the stern tube for a reference, but what do you guys think?
Cheers - Jeff
Cheers - Jeff
