Replacement Stantion Bases
Joey Sowell
Does anyone know of a replacement stantion for the extruded aluminum bases that come on a 1985 31' Hunter? I also need a replacement bow rail.
Paul Akers
Check with Hunter
They may be able to manufacture an extruded aluminum stanchion base.
Phil Herring
Alien
Mar 25, 1997
4,923
- - Bainbridge Island
The source is gone
Actually, Hunter asked us to let them know if we find a source. They're cast aluminum so your machine shop down the block can't make them. We have found a source, although they probably won't be aluminum, but stainless with a buffer material (probably plastic) to fight corrosion. We're just working out the design details and measuring instructions. If the shop is reasonably responsive it won't be too long. ph.
Phil Herring
Alien
Mar 25, 1997
4,923
We've been told cast
I believe both Hunter and the shop working on this have described the base as cast aluminum. But I'm passing this stuff along second-hand, Bly is really in the middle of it. I just take what she gives me and stick it in the middle of some html. :)
