Replacement stanchions available?
K
Kevin Filer
I need to replace a bent stanchion, but I haven't found the matching stanchion in my area or on any of the web sites I normally check. I know I can replace ALL the stanchions with new ones, but I'd prefer to find one that matches what I have. Vertical part holds two lines, is about 25 in tall, and is welded to the base. The base has two curved supports. Anyone found matching replacements for the OEM stuff? Goes on a 79 H30. Thanks, Kevin
Dec 2, 1999
15,184
They are available in the HOW store.
Kevin: They are available here in the HOW store. If you do not see what you want give them a call. They will reproduce what you have.
E
Ed Schenck
TIQ?
Not sure who makes the stanchions for the HOW store but as Steve points out give them a shot. But I know that TIQ does quality work and can match almost anything. That would be my next stop, see Related Link.
I
Ian McGain
bent stantions
Two season's ago, snow load on the tarp covering my 79 30' on the hard/jack stands broke two stantions at the base. I took them to a small shop that advertised stainless steel welding. For $45.00 they welded them back together. A similiar type shop might be able to fix yours depending on the problem. Good luck Ian
