Replacement Solar Panel for Hunter 380
7
2 380 Falmouth, MA
I'm looking at replacing the solar panel (and the fiberglass inset that it is mounted to) on a Hunter 380. I cannot find any online ordering information. Do I have to go to a dealer or are there online sites that I can use to order replacement parts?
Thanks,
Tom
7,504
Alden 50 Sarasota, Florida
Don't have the phone number handy but Hunter has a parts department which might be your best chance of finding what you need.
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
Hi,
This has cropped up several times in the past, both with the H380 and the H376 which I believe uses the identical panel and surround.
With luck you should find all this in the archives, including contributions from myself.
Good luck and if you are out of luck please e-mail me as I can advise - but it will take quite a bit of research.
Regards.
